    M5StackSAM - Application Menu Library
    14 Posts 7 Posters 48.0k Views 1 Watching
      kaotiklabs
      @TomSuch Thanks! I think this will be really helpful.
      Don't need to waste time setting a my quick dirty menu anymore :)
      • JJJ Offline
        JJ @TomSuch
        @tomsuch
        Nice one Tom. Thanks. Should be handy for many users....
        • reaper7R Offline
          reaper7
          simple app Accu meter (MAX17043 module soldered inside Battery Module):
          code based on nlamprian library from https://github.com/nlamprian/LiFuelGauge:
          available on my gist:
          https://gist.github.com/reaper7/c9f8dba68edae8c3d53075b10f6bbba4
          J 1 Reply Last reply Reply Quote 4
          • 面 Offline
            面包
            不知楼主是否看得懂中文~哈哈
            这个例子非常好,已经借用,谢谢作者TomSuch~
            另外,建议做菜单列表,比现在的菜单页面直观一些。
            APPLICATION
            1.APP1
            2.APP2
            3.RETRUN
            SYSTEM
            1.SYSTEM INFO
            2.SLEEP/..
            3.RETRUN
              jwdberlin @reaper7
              @reaper7 shows strange values: VCell: -0.0213V SoC: -1.00%
              what's going wrong?
              • JJJ Offline
                JJ
                @jwdberlin
                Hi, just checking... have you added a MAX17043 "battery gauge module" to your M5Stack in some way - perhaps soldered to the add-on Battery module as per reaper7's example ?
                • reaper7R Offline
                  reaper7
                  @jwdberlin - i2c scanner app show max17043 at address 0x36?, your master ino has Wire.begin(); ?
                  Try first with regular library:
                  https://github.com/nlamprian/LiFuelGauge/
                  @JimiT - good question :)
                  • JJJ Offline
                    JJ @reaper7
                    @reaper7
                    Hi Reaper7, I'm planning to do this mod.
                    Could you please share some details on how you've wired the MAX17043 ? I am sure others would also be interested.
                    So you've removed the battery connector from the MAX. Looks like you are using 7 of the 8 pins on the the MAX... NOT using the Quick start QSTRT pin from what I can see. Then i presume SDA to G21 on M5Stack; SCL to G22 on M5Stack....
                    Is that right? And the rest ? Thanks !
                    • reaper7R Offline
                      reaper7
                      cutting pcb is not necessary,
                      cutting wire between ACCU+ and VCC also not necessary
                      but I do not want drain accu by max17043 when m5stack is off
                      REMEMBER! If wire between ACCU+ and VCC are not cut (on the max17043 pcb) as it is originally,
                      then connect only ACCU+ pin to M-BUS BATTERY and DO NOT connect VCC to M-BUS 3.3V
                      JJJ 1 Reply Last reply Reply Quote 2
                      • JJJ Offline
                        JJ @reaper7
                        @reaper7
                        Excellent thanks very much !
                          jwdberlin @JJ
                          @jimit Thanks - after rereading I noticed that a separate module is needed :-) Just ordered some of those...
                            DoNcK
                            A bit off-topic:
                            Can someone using a battery gauge indicate how long does the 150mah battery takes to charge on an M5Stack limited edition ? (assuming ESP is sleeping)
                            (FYI, with the screen backlight turned off, and not connected to any network, the battery lasted for 40 minutes with the ESP not sleeping)
                              TomSuch
                              A new version of the M5StackSAM library
                              https://github.com/tomsuch/M5StackSAM
                              Added features to easily create and navigate the list.
                              (APPLICATIONS -> LIST DEMO)
                              Added support for the FACES QWERTY keyboard.
                              (APPLICATIONS -> FACES GET STRING)
