    M5StackSAM - Application Menu Library
    14 Posts 7 Posters 48.0k Views 1 Watching
    • JJJ Offline
      JJ @TomSuch
      @tomsuch
      Nice one Tom. Thanks. Should be handy for many users....
      • reaper7R Offline
        reaper7
        simple app Accu meter (MAX17043 module soldered inside Battery Module):
        code based on nlamprian library from https://github.com/nlamprian/LiFuelGauge:
        available on my gist:
        https://gist.github.com/reaper7/c9f8dba68edae8c3d53075b10f6bbba4
        J 1 Reply Last reply Reply Quote 4
        • 面 Offline
          面包
          不知楼主是否看得懂中文~哈哈
          这个例子非常好,已经借用,谢谢作者TomSuch~
          另外,建议做菜单列表,比现在的菜单页面直观一些。
          APPLICATION
          1.APP1
          2.APP2
          3.RETRUN
          SYSTEM
          1.SYSTEM INFO
          2.SLEEP/..
          3.RETRUN
            jwdberlin @reaper7
            @reaper7 shows strange values: VCell: -0.0213V SoC: -1.00%
            what's going wrong?
            • JJJ Offline
              JJ
              @jwdberlin
              Hi, just checking... have you added a MAX17043 "battery gauge module" to your M5Stack in some way - perhaps soldered to the add-on Battery module as per reaper7's example ?
              • reaper7R Offline
                reaper7
                @jwdberlin - i2c scanner app show max17043 at address 0x36?, your master ino has Wire.begin(); ?
                Try first with regular library:
                https://github.com/nlamprian/LiFuelGauge/
                @JimiT - good question :)
                • JJJ Offline
                  JJ @reaper7
                  @reaper7
                  Hi Reaper7, I'm planning to do this mod.
                  Could you please share some details on how you've wired the MAX17043 ? I am sure others would also be interested.
                  So you've removed the battery connector from the MAX. Looks like you are using 7 of the 8 pins on the the MAX... NOT using the Quick start QSTRT pin from what I can see. Then i presume SDA to G21 on M5Stack; SCL to G22 on M5Stack....
                  Is that right? And the rest ? Thanks !
                  • reaper7R Offline
                    reaper7
                    cutting pcb is not necessary,
                    cutting wire between ACCU+ and VCC also not necessary
                    but I do not want drain accu by max17043 when m5stack is off
                    REMEMBER! If wire between ACCU+ and VCC are not cut (on the max17043 pcb) as it is originally,
                    then connect only ACCU+ pin to M-BUS BATTERY and DO NOT connect VCC to M-BUS 3.3V
                    JJJ 1 Reply Last reply Reply Quote 2
                    • JJJ Offline
                      JJ @reaper7
                      @reaper7
                      Excellent thanks very much !
                        jwdberlin @JJ
                        @jimit Thanks - after rereading I noticed that a separate module is needed :-) Just ordered some of those...
                          DoNcK
                          A bit off-topic:
                          Can someone using a battery gauge indicate how long does the 150mah battery takes to charge on an M5Stack limited edition ? (assuming ESP is sleeping)
                          (FYI, with the screen backlight turned off, and not connected to any network, the battery lasted for 40 minutes with the ESP not sleeping)
                            TomSuch
                            A new version of the M5StackSAM library
                            https://github.com/tomsuch/M5StackSAM
                            Added features to easily create and navigate the list.
                            (APPLICATIONS -> LIST DEMO)
                            Added support for the FACES QWERTY keyboard.
                            (APPLICATIONS -> FACES GET STRING)
