    M5StackSAM - Application Menu Library
    14 Posts 7 Posters 48.0k Views 1 Watching
    • 面 Offline
      面包
      不知楼主是否看得懂中文~哈哈
      这个例子非常好,已经借用,谢谢作者TomSuch~
      另外,建议做菜单列表,比现在的菜单页面直观一些。
      APPLICATION
      1.APP1
      2.APP2
      3.RETRUN
      SYSTEM
      1.SYSTEM INFO
      2.SLEEP/..
      3.RETRUN
        jwdberlin @reaper7
        @reaper7 shows strange values: VCell: -0.0213V SoC: -1.00%
        what's going wrong?
        • JJJ Offline
          JJ
          @jwdberlin
          Hi, just checking... have you added a MAX17043 "battery gauge module" to your M5Stack in some way - perhaps soldered to the add-on Battery module as per reaper7's example ?
          • reaper7R Offline
            reaper7
            @jwdberlin - i2c scanner app show max17043 at address 0x36?, your master ino has Wire.begin(); ?
            Try first with regular library:
            https://github.com/nlamprian/LiFuelGauge/
            @JimiT - good question :)
            • JJJ Offline
              JJ @reaper7
              @reaper7
              Hi Reaper7, I'm planning to do this mod.
              Could you please share some details on how you've wired the MAX17043 ? I am sure others would also be interested.
              So you've removed the battery connector from the MAX. Looks like you are using 7 of the 8 pins on the the MAX... NOT using the Quick start QSTRT pin from what I can see. Then i presume SDA to G21 on M5Stack; SCL to G22 on M5Stack....
              Is that right? And the rest ? Thanks !
              • reaper7R Offline
                reaper7
                cutting pcb is not necessary,
                cutting wire between ACCU+ and VCC also not necessary
                but I do not want drain accu by max17043 when m5stack is off
                REMEMBER! If wire between ACCU+ and VCC are not cut (on the max17043 pcb) as it is originally,
                then connect only ACCU+ pin to M-BUS BATTERY and DO NOT connect VCC to M-BUS 3.3V
                JJJ 1 Reply Last reply Reply Quote 2
                • JJJ Offline
                  JJ @reaper7
                  @reaper7
                  Excellent thanks very much !
                    jwdberlin @JJ
                    @jimit Thanks - after rereading I noticed that a separate module is needed :-) Just ordered some of those...
                      DoNcK
                      A bit off-topic:
                      Can someone using a battery gauge indicate how long does the 150mah battery takes to charge on an M5Stack limited edition ? (assuming ESP is sleeping)
                      (FYI, with the screen backlight turned off, and not connected to any network, the battery lasted for 40 minutes with the ESP not sleeping)
                        TomSuch
                        A new version of the M5StackSAM library
                        https://github.com/tomsuch/M5StackSAM
                        Added features to easily create and navigate the list.
                        (APPLICATIONS -> LIST DEMO)
                        Added support for the FACES QWERTY keyboard.
                        (APPLICATIONS -> FACES GET STRING)
