    How do I concat strings in ui flow
    12 Posts 4 Posters 31.1k Views 1 Watching
      alon24
      How do I concat strings?
      I want to have a timer, and a label on screen 00 01 02 ....
      I want to create the string from seconds, so that if it is less than 10 0+seconds
      so in a function:
      varaible tmp;
      if (sec<10) variable ="0" + string of secs ====> concat string
      else variable = string of secs
      How in ui flow
        ajb2k3 @alon24
        @alon24 Sorry what is concat strings?
        if you are unsure of english words try posting in your language.
        DINK74D 1 Reply Last reply Reply Quote 0
          alon24
          "hello" + "world" => "hello world"
          "0" + "1" => "01"
            alon24
            https://en.wikipedia.org/wiki/Concatenation
              surely if and else are showing the same thing?
              I'm feeling confused but its something like this.
              NOT complete!
              alt text
                alon24
                I do not think you understand, I want to create a new string to show.
                Say I have "hello" and "world" I want to. Create a new string with "hello world" in it.
                In js:
                Let a= "hello" + "world"
                Now a== "hello world"
                Hope this is now more understandable, it should be in the text section, something like join action for text
                  alon24
                  Can u add https://github.com/google/blockly/wiki/Text#text-creation
                  The create with and append to
                    ajb2k3 @alon24
                    @alon24 said in How do I concat strings in ui flow:
                    In js:
                    You are correct, I didn't understand.
                    Hmn, nope I can't find away to do it in UIFlow however there should be away in micropython which is the underlying programming language.
                    Sorry, I can't help you anymore here.
                    • L Offline
                      LastCaress
                      Doesn't this work?
                      alt text
                      In micropython it would be the same as python : stringA + stringB
                        alon24
                        So this worked, because I needed numbers
                          ajb2k3 @alon24
                          Would you mind if I added this to my book?
                          • DINK74D Offline
                            DINK74 @ajb2k3
                            @ajb2k3 Actually, “concat” is a widely recognized and valid term in programming that refers to combining two or more strings. There’s no need to be condescending to a fellow programmer by telling them to “use his language.” He's used English in understandable manner.
