    M5StickC: turn off screen completely
    25 Posts 11 Posters 110.5k Views 3 Watching
      dda
      I poked around the APX192 code, and around a datasheet found here. First, there's this code:
      void AXP192::begin(void) {
        Wire1.begin(21, 22);
        Wire1.beginTransmission(0x34);
        Wire1.write(0x10);
        Wire1.write(0xff);  //OLED_VPP Enable
        Wire1.endTransmission();
        Wire1.write(0x28);
        Wire1.write(0xff); //Enable LDO2&LDO3, LED&TFT 3.3V
      A peek at the datasheet says that REG 28H is power management for LD02 and LD03. Sure thing. That's what the comment in the code above says – along with a hint that LD03 is for the TFT.
      Meanwhile, REG 10H is two ON/OFF switches, for EXTEN and DC-DC2 – commented in the code as VPP_Enable. Bueno.
      I am not sure which of EXTEN or DC-DC2 is connected to the OLED (both?), but turning either or both off will cut off the current to the OLED.
      Moreover there's this code later:
        Wire1.write(0x12);
        Wire1.write(0x4d); //Enable DC-DC1, OLED_VDD, 5B V_EXT
      And REG 12H seems to do more of the same as 10H:
      Bit 3 turns ON/OFF LD03, which, as we saw above, is supposed to be the OLED. Good odds that setting bit 3 of REG 12H to zero would work too.
      I don't have time to test it now, but I'll try later tonight.
        dda
        After a little bit of poking around I managed to turn off the screen:
        Wire1.write(0x12);
        Wire1.write(0b01001011);  // LDO2, aka OLED_VDD, off
        This turns off LDO2, and thus the backlight. To turn it back on:
        Wire1.write(0x12);
        Wire1.write(0x4d); // Enable LDO2, aka OLED_VDD
        W 1 Reply Last reply Reply Quote 2
        • W Offline
          ws1088 @dda
          @dda Thanks! @ricardocosta can probably check to see how much current is used when backlight is off.
            dda
            While I'm at it, an explanation about M5.Axp.ScreenBreath(x);. The code is:
            void AXP192::ScreenBreath(uint8_t brightness) {
              Wire1.write(0x28);
              Wire1.write(((brightness & 0x0f) << 4)); //Enable LDO2&LDO3, LED&TFT 3.3V
            What it does is it takes the value you passed, cuts it to 4 bits (0-15) and moves those 4 bits to bits 4-7. Register 28H is voltage control for LDO2 (bits 4-7) and LDO3 (bits 0-3). So the OLED is connected to LDO2.
            What that 0-15 value represents is a voltage of 1.8 to 3.3V, in 100mV/steps. So M5.Axp.ScreenBreath(0); sets voltage to 1.8V, and M5.Axp.ScreenBreath(15); to 3.3V. Not what we really want – as the goal was to set voltage to zero... :-)
            Whereas register 12H controls the state (ON/OFF) of a bunch of wires, including LDO2 (bit 2). Hence the code above.
            • W Offline
              ws1088
              Does your code cut the voltage to the backlight only? or to the screen as well?
                dda
                To be tested but I think this turns off OLED_VDD, ie the current to the OLED. Register 10H is said to be for OLED_VPP so setting it to zero could help too.
                  dda
                  I did a simple test: with only REG 28H the screen stays slightly warm. With both 28H and 10H, the screen cools off after a while. Hardly a scientific test, I know, but seems to point to the need to set both registers.
                  W K 2 Replies Last reply Reply Quote 0
                  • W Offline
                    ws1088 @dda
                    @dda what a wonderful work you have done! I hope this will enable @Multihelix to use M5StickC as a watch (turn off OLED after a timeout and turn on OLED on button press or accelerometer)
                      maxstack @Multihelix
                      @multihelix
                      How are you getting 5 hours of life? it seems you would need <16 ma total drain
                      Are you sleeping the ESP32?
                        dda @ws1088
                        @ws1088 Funny enough I bought my M5StickC with the watch strap and all, but not because I wanted a watch – I don't wear them – but because it enables me to tie it up to my backpack when I do LoRa range tests :-)
                        • W Offline
                          ws1088 @dda
                          @dda said in M5StickC: turn off screen completely:
                          why would you use m5stickc to do LoRa range tests? You can get LoRa chip with OLED screen. Do you connect m5stickc to a LoRa chip via I2C? or WiFi AP?
                            dda
                            I have a lot of different LoRa chips and setups. I have one board, at 230 MHz, that I can connect through the hat connector (I need 3 pins + Vcc/GND). I have transceivers, both at 230 and 433 MHz, I connect to via RS485 (I bought a hat for that, and also some RS485 for my M5Stack cores). etc etc. The smaller the better :-)
                              Multihelix @maxstack
                              @maxstack - Yes, I used ESP DeepSleep set to wake on Button A being pressed, but I would say that the 5 hour time was not under ideal conditions, as I occasionally woke up the device to confirm it was still working and to check the time - a resonable activity for a watch.
                                spiffmonious @Multihelix
                                @multihelix Can you post a link to your watch code?
                                  klimbot @dda
                                  I'm looking at this thread to hopefully implement a complete screen turn off, but am not sure what register mask to use (based on quoted post)
                                  Here is what I have, the screen is off but hard to know if the screen has actually been disabled.
                                  void turnOffScreen() {
                                  Wire1.write(0x10);
                                  Wire1.write(0b00000000); // 7-3=? | 2=EXTEN | 1=? | 0=DC-DC2
                                  Wire1.write(0x12);
                                  Wire1.write(0b01001011); // 7=? | 6=EXTEN | 5=? | 4=DC-DC2 | 3=LDO3 | 2=LDO2 | 1=DC-DC3 | 0=DC-DC1
                                  Wire1.write(0x28);
                                  Wire1.write(0b00001111); // 7-4=LDO2 | 3-0=LDO3
                                    ForestRupicolous
                                    @klimbot: I think you have to turn LDO3 and LDO2 off, in your code only LDO2 is off. Take a look at this picture: https://docs.m5stack.com/assets/img/product_pics/core/minicore/m5stickc/m5stickc_05.webp
                                    • V Offline
                                      viandou
                                      This is how I init my M5StickC in a full black screen way.
                                      M5.begin(0,1,1);
                                      M5.Axp.SetLDO2(false);
                                      M5.Axp.SetLDO3(false);
