    M5StickC: turn off screen completely
    25 Posts 11 Posters 110.5k Views 3 Watching
    • W Offline
      ws1088
      Does your code cut the voltage to the backlight only? or to the screen as well?
        dda
        To be tested but I think this turns off OLED_VDD, ie the current to the OLED. Register 10H is said to be for OLED_VPP so setting it to zero could help too.
          dda
          I did a simple test: with only REG 28H the screen stays slightly warm. With both 28H and 10H, the screen cools off after a while. Hardly a scientific test, I know, but seems to point to the need to set both registers.
          W K 2 Replies Last reply Reply Quote 0
          • W Offline
            ws1088 @dda
            @dda what a wonderful work you have done! I hope this will enable @Multihelix to use M5StickC as a watch (turn off OLED after a timeout and turn on OLED on button press or accelerometer)
              maxstack @Multihelix
              @multihelix
              How are you getting 5 hours of life? it seems you would need <16 ma total drain
              Are you sleeping the ESP32?
                dda @ws1088
                @ws1088 Funny enough I bought my M5StickC with the watch strap and all, but not because I wanted a watch – I don't wear them – but because it enables me to tie it up to my backpack when I do LoRa range tests :-)
                • W Offline
                  ws1088 @dda
                  @dda said in M5StickC: turn off screen completely:
                  why would you use m5stickc to do LoRa range tests? You can get LoRa chip with OLED screen. Do you connect m5stickc to a LoRa chip via I2C? or WiFi AP?
                    dda
                    I have a lot of different LoRa chips and setups. I have one board, at 230 MHz, that I can connect through the hat connector (I need 3 pins + Vcc/GND). I have transceivers, both at 230 and 433 MHz, I connect to via RS485 (I bought a hat for that, and also some RS485 for my M5Stack cores). etc etc. The smaller the better :-)
                      Multihelix @maxstack
                      @maxstack - Yes, I used ESP DeepSleep set to wake on Button A being pressed, but I would say that the 5 hour time was not under ideal conditions, as I occasionally woke up the device to confirm it was still working and to check the time - a resonable activity for a watch.
                        spiffmonious @Multihelix
                        @multihelix Can you post a link to your watch code?
                          klimbot @dda
                          I'm looking at this thread to hopefully implement a complete screen turn off, but am not sure what register mask to use (based on quoted post)
                          Here is what I have, the screen is off but hard to know if the screen has actually been disabled.
                          void turnOffScreen() {
                          Wire1.beginTransmission(0x34);
                          Wire1.write(0x10);
                          Wire1.write(0b00000000); // 7-3=? | 2=EXTEN | 1=? | 0=DC-DC2
                          Wire1.endTransmission();
                          Wire1.begin(21, 22);
                          Wire1.write(0x12);
                          Wire1.write(0b01001011); // 7=? | 6=EXTEN | 5=? | 4=DC-DC2 | 3=LDO3 | 2=LDO2 | 1=DC-DC3 | 0=DC-DC1
                          Wire1.write(0x28);
                          Wire1.write(0b00001111); // 7-4=LDO2 | 3-0=LDO3
                            ForestRupicolous
                            @klimbot: I think you have to turn LDO3 and LDO2 off, in your code only LDO2 is off. Take a look at this picture: https://docs.m5stack.com/assets/img/product_pics/core/minicore/m5stickc/m5stickc_05.webp
                            • V Offline
                              viandou
                              This is how I init my M5StickC in a full black screen way.
                              M5.begin(0,1,1);
                              M5.Axp.SetLDO2(false);
                              M5.Axp.SetLDO3(false);
