    M5StickV Firmware_1017 Upgrade
    24 Posts 7 Posters 98.0k Views 1 Watching
    • m5stackM Online
      M5StickV Firmware_1017 Upgrade time : 2019.10.17
      Log:
      1. Add _thread Module
      2. Fix AVI Play Bug
      3. Add Resize(zoom in/out) Support for RGB565
      4. Fix SD partition Number
      5. Fix _boot.py
      6. Add PMU Module
      7. Fix PMIC Settings Bug
      8. Enable PMIC Sleep mode in boot.py
      New functions:
      enablePMICSleepMode
      from pmu import axp192
      pmu = axp192()
      pmu.enablePMICSleepMode(True)
      Introduction: Incoming True or False , True starts button detection,False cancel the detections, Button short press reset long press
      All the power is turned off under sleep mode, which should identical to the normal meaning of shutdown, but we adopt the idea from AXP192 datasheet as Sleep Mode.
      setScreenBrightness
      pmu = axp192()
      pmu.setScreenBrightness(10):
      Introduction: Incoming -0~15 Integer adjust the screen brightness
      Firmwae Download links:
      https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/M5StickV_Firmware_1017.kfpkg
      Easyloader Download links (For Windows):
      https://m5stack.oss-cn-shenzhen.aliyuncs.com/EasyLoader/M5Core/M5StickV/EasyLoader_M5StickV_1017.exe
      Github(pmu.py):
      https://github.com/MarsTechHAN/MaixPy/blob/master/projects/maixpy_m5stickv/builtin_py/pmu.py
      • X Offline
        Xeon
        Will be testing now.
        Tested new firmware and updates to pmu.
        So far everything looks very good.
        Thanks for the quick update.
        The war of 1 and 0 draws ever closer.
        everyday i work to become a cyborg.
          Thrasher
          m5stack,
          Hello, I've updated my Stick-V today
          Trained a model and ran it through http://v-training.m5stack.com/ (I did that before couple of times, went ok)
          Now when I download trained model, uploading it on sd-card, inserting inside Stick-V it wont boot
          Loading stucks at logo.
          Im bit confused with that :C
          S m5stackM 2 Replies Last reply Reply Quote 0
            staberas @Thrasher
            @thrasher
            does the sd contain the project? (boot.py)
            if yes then upload it on the flash memory via maixpy and rename the "boot.py" on the sd card to "_boot.py"
              Thrasher
              @staberas
              Okay, will give it a try. Usually used simply copy files to sd card and it used to work well (alrdy did tests with old firmware)
                Thrasher
                Didn't work.
                Tried both upload file and "save open script to board(boot.py)
                No effect at all
                Does anyone there have old firmware so I can try with it?
                  staberas @Thrasher
                  @thrasher
                  http://dl.sipeed.com/MAIX/MaixPy/release/master/
                    Thrasher
                    @staberas
                    Thank you. I've tried this - "maixpy_v0.4.0_6_g715665c_m5stickv.bin" with kflash_gui.
                    Works like a charm now and power button also works correct (lol)
                    • SkinkS Offline
                      Skink
                      I've been taking this version online at yesterday.
                      (Link: http://dl.sipeed.com/MAIX/MaixPy/release/master/)
                      Version : maixpy_v0.4.0_66_g4ab9e8d and also with this version switching off the stick works now !!
                        Cant use Kflash gui on my OSX install. Whats the command line to install the firmware?
                        • SkinkS Offline
                          Skink
                          I don't know if this will help you because I don't have an Apple!
                          Kflash
                          3, For people who are used to use command line, Kflash could be an alternative option.[Click here for details](https://github.com/kendryte/kflash.py)
                          Reiner
                            FPSychotic
                            What is PMU module?
                            • m5stackM Online
                              m5stack @FPSychotic
                              @fpsychotic power managment unit
                              • m5stackM Online
                                m5stack @Thrasher
                                @thrasher hi thanks your reply , we will as soon solve this problem.
                                • X Offline
                                  Xeon
                                  I am making a manual that tries to fullty detail all functions for the m5stickV and K210
                                  is this ok?
                                  Would people support this?
                                  m5stackM T 2 Replies Last reply Reply Quote 2
                                  • m5stackM Online
                                    m5stack @Xeon
                                    @xeon Nice !
                                      Thrasher @Xeon
                                      @xeon
                                      Sure that would be awesome. Especially UART and other things becayse Maix manuals say nothing about it.
                                      There's a thread already ran to collect all things about Stick-V, could you keep it updated so we gather all necessar info in one thread ? here it is - http://forum.m5stack.com/topic/1226/m5stickv-link-info-dump/1
                                      X 1 Reply Last reply Reply Quote 1
                                      • X Offline
                                        Xeon @Thrasher
                                        @thrasher
                                        Well i'm going to start by documenting all the functions in the maix core and then start fleshing it out.
                                        I created a git to hold manual but right now it just a mess.
                                        And will open it up to others to help flesh it out in detail.
                                        A lot of stuff is not documented.
                                        Some stuff can easily be described.
                                        Other stuff needs me to read thru data sheets carefully.
                                        I'll also be looking into our microphone issue.
                                        And supplying links to more articles on growing the AI platform.
                                          ajb2k3 @Xeon
                                          @xeon said in M5StickV Firmware_1017 Upgrade:
                                          @thrasher
                                          Welcome to my world @Xeon
                                            Thrasher
                                            @ajb2k3 @Xeon
                                            I can help to translate into russian, with time.
                                            Whenever Ill have spare minute
