    M5StickV Firmware_1017 Upgrade
    24 Posts 7 Posters 98.0k Views 1 Watching
      staberas @Thrasher
      @thrasher
      http://dl.sipeed.com/MAIX/MaixPy/release/master/
        Thrasher
        @staberas
        Thank you. I've tried this - "maixpy_v0.4.0_6_g715665c_m5stickv.bin" with kflash_gui.
        Works like a charm now and power button also works correct (lol)
        • SkinkS Offline
          Skink
          I've been taking this version online at yesterday.
          (Link: http://dl.sipeed.com/MAIX/MaixPy/release/master/)
          Version : maixpy_v0.4.0_66_g4ab9e8d and also with this version switching off the stick works now !!
            Cant use Kflash gui on my OSX install. Whats the command line to install the firmware?
            • SkinkS Offline
              Skink
              I don't know if this will help you because I don't have an Apple!
              Kflash
              3, For people who are used to use command line, Kflash could be an alternative option.[Click here for details](https://github.com/kendryte/kflash.py)
              Reiner
                FPSychotic
                What is PMU module?
                • m5stackM Online
                  m5stack @FPSychotic
                  @fpsychotic power managment unit
                  • m5stackM Online
                    m5stack @Thrasher
                    @thrasher hi thanks your reply , we will as soon solve this problem.
                    • X Offline
                      Xeon
                      I am making a manual that tries to fullty detail all functions for the m5stickV and K210
                      is this ok?
                      Would people support this?
                      The war of 1 and 0 draws ever closer.
                      everyday i work to become a cyborg.
                      m5stackM T 2 Replies Last reply Reply Quote 2
                      • m5stackM Online
                        m5stack @Xeon
                        @xeon Nice !
                          Thrasher @Xeon
                          @xeon
                          Sure that would be awesome. Especially UART and other things becayse Maix manuals say nothing about it.
                          There's a thread already ran to collect all things about Stick-V, could you keep it updated so we gather all necessar info in one thread ? here it is - http://forum.m5stack.com/topic/1226/m5stickv-link-info-dump/1
                          X 1 Reply Last reply Reply Quote 1
                          • X Offline
                            Xeon @Thrasher
                            @thrasher
                            Well i'm going to start by documenting all the functions in the maix core and then start fleshing it out.
                            I created a git to hold manual but right now it just a mess.
                            And will open it up to others to help flesh it out in detail.
                            A lot of stuff is not documented.
                            Some stuff can easily be described.
                            Other stuff needs me to read thru data sheets carefully.
                            I'll also be looking into our microphone issue.
                            And supplying links to more articles on growing the AI platform.
                              ajb2k3 @Xeon
                              @xeon said in M5StickV Firmware_1017 Upgrade:
                              @thrasher
                              Welcome to my world @Xeon
                                Thrasher
                                @ajb2k3 @Xeon
                                I can help to translate into russian, with time.
                                Whenever Ill have spare minute
                                  ajb2k3 @Thrasher
                                  @thrasher said in M5StickV Firmware_1017 Upgrade:
                                  @ajb2k3 @Xeon
                                  Thank you your support will be most appreciated
                                    staberas
                                    new bug:
                                    "pmu import axp192" interferes when i try to get gyro/accel data from the MPU6886
                                    • m5stackM Online
                                      m5stack @staberas
                                      @staberas actually it not a bug . the K210 only three I2C interface, camera ,and some hardware dafuit use two interface . then PMU use one interface , if you want to use IMU , you shoud be Reasonable distribution I2C interface.
                                        staberas
                                        im not sure i understand, can u provide an example ?
                                        EDIT: it works now i have to comment out those two:
                                        #pmu = axp192()
                                        #pmu.enablePMICSleepMode(True)
                                        when added they the IMU locks up
