    M5StickV Firmware_1022_beta Upgrade
    21 Posts 6 Posters 86.2k Views 1 Watching
      Thrasher
      @staberas wows, thanks, I will check it
      However, I havent modified code, got it straight from V-Trainer. Im also confused because everything works on maix firmwares as intended :/
        staberas @Thrasher
        @thrasher
        i also did for me because maix editor fixes the whitespacing before uploading, if you edited the file in text mode like me you probable added some wrong whitespace character without knowing
          ajb2k3 @Thrasher
          @thrasher The firmware only works on fat32 cards
          Class 10 UHC1 cards work fine, anything above this and you will probably run into issues.
          What card are you using and how was it formatted. If you used OSX then you need to reformat using the SDfoundation tool.
          • X Offline
            Xeon @Thrasher
            @thrasher https://www.sdcard.org/downloads/formatter/
            try this.
            i prefer using a high quality SD since i hacked my first psp.
            I learned fast a good SD card saves money later.
            i got a supplier that gets me bulk sd cards at a huge discount.
            All of them Samsung Class 10 UHC1 and above.
            they just last longer because i tend to put SD cards thru hell in elaborate builds.
            The war of 1 and 0 draws ever closer.
            everyday i work to become a cyborg.
              @xeon said in M5StickV Firmware_1022_beta Upgrade:
              try this.
              I'm using 32GB Toshiba cards that are Class 10 UHC 1 as I got them on discount however I am yet to program my stickV as I can't get Kflash GUI to work.
              • X Offline
                Xeon @ajb2k3
                @ajb2k3 said in M5StickV Firmware_1022_beta Upgrade:
                try this.
                Why?
                  ajb2k3 @Xeon
                  try this.
                  Why?
                  KFlash GUI just starts then shuts down strait away
                    ajb2k3 @ajb2k3
                    kflash_gui ; exit;
                      File "kflash_gui.py", line 5, in <module>
                      File "<frozen importlib._bootstrap>", line 983, in _find_and_load
                      File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
                      File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
                      File "/usr/local/lib/python3.7/site-packages/PyInstaller/loader/pyimod03_importers.py", line 627, in exec_module
                      File "paremeters_save.py", line 6, in <module>
                      File "/usr/local/Cellar/python/3.7.3/Frameworks/Python.framework/Versions/3.7/lib/python3.7/locale.py", line 568, in getdefaultlocale
                      File "/usr/local/Cellar/python/3.7.3/Frameworks/Python.framework/Versions/3.7/lib/python3.7/locale.py", line 495, in _parse_localename
                    ValueError: unknown locale: UTF-8
                    [726] Failed to execute script kflash_gui
                    logout
                    Saving session...
                    ...copying shared history...
                    ...saving history...truncating history files...
                    ...completed.
                      Thrasher
                      @Xeon @ajb2k3
                      I have sundisk extreme cards and samsung pro ones from my camera and dji phantom, so they are 100% legit but stickv wont recognize em. I went to cheaper ones and still had no success (i think it was kingstones) so I found old 1gb one in my stash from some old hardware and it worked fine until last firmwares. I saw someone else expierencing same problems here
                        pnnato
                        Can anyone make the SD XC-typed card work with exFat format?
                          ajb2k3 @pnnato
                          @pnnato I don't think exfat is supported by any electronic device.
                            pnnato @ajb2k3
                            @ajb2k3 Wow. such a quick reply. Thanks.
                            At first, I just couldn't format my SD card to FAT32 using Windows, but I found another solution using software like "MiniTool Partition Wizard" to change exFat to FAT32. And boot.py can work now.
                              ajb2k3 @pnnato
                              @pnnato If all else fails use the sd formatter from https://www.sdcard.org/downloads/formatter/
                              • m5stackM Online
                                m5stack @Thrasher
                                @thrasher hi , maybe because the model file too big. you could use V-Training serve to Training a new Model , then will be solve
