    About Hat 8servos
    11 Posts 3 Posters 21.5k Views 1 Watching
      Can you share a screen shot of you UIFlow code please?
        coffeeworm
          coffeeworm
          I record a mp4 video. The RGB worked but Servo not.
          https://youtu.be/iymi3ziUE7M
            if you put pressure on the servo horn, does the horn move?
              coffeeworm
              @ajb2k3 said in About Hat 8servos:
              pressure
              When the program is executed, the pressure on the servo horn is rotatable.
              X ajb2k3A 2 Replies Last reply Reply Quote 0
              • X Offline
                Xeon @coffeeworm
                @coffeeworm
                Sounds like your not getting power.
                The war of 1 and 0 draws ever closer.
                everyday i work to become a cyborg.
                  ajb2k3 @coffeeworm
                  @coffeeworm said in About Hat 8servos:
                  pressure
                  as @Xeon replied, you dont have power to the servos. is the power switch in the correct position?
                    coffeeworm
                    Yes,the power is switch in the correct position.
                    I am sure that it is not a power problem.
                      coffeeworm
                      I found a solution, I have to set it up first, then the servo can work.
                      Thank you for your response.
                        Ah, that is worth Knowing thanks.
                        I haven't got one yet so didn't know that they needed a "Initial Position" set up.
                        Thank you for working this out.
