    USB Mode
    3 Posts 3 Posters 5.9k Views 1 Watching
      marc.moennikes
      i have ordered a M5Stack IoTKit.
      It is a makerfactory kit.
      I want to use local flow ide, but there is no USB mode available.
      Only Wifi Connection possible, no entry USB Mode on M5Stack Core :-(
      How can I enter USB Mode?
      i can not flash firmware with burner, USB connection not working.
      Can anybody help me?
      Regards
      Marc
        Thrasher
        Go to M5Burner menu from UIFlow, select your device's COM port, speed should be 115200, select latest firmware available and make sure you select correct core. Reflash
        With every start you have couple of seconds to hit "setup" on your device and select USB Mode there.
        • m5stackM Online
          you could follow this tutorial , then learn how to setup the usb mode
          https://docs.m5stack.com/#/en/uiflow/UIFlow_Desktop_IDE
