    UiFlow 1.4.3
    12 Posts 8 Posters 24.0k Views 2 Watching
    • m5stackM Offline
      Ver 1.4.3. time : 2019.12.27
      UpdateLog:
      • 1: Add: BaseX.
      • 2: Add: Server china and singapore select in setting.
      • 3: Fixed: in http request, it no longer auto converts string to json data.
      • 4: StickC: Fixed pahub unit support.
      • 5: StickC: Add: hat yun add humidity and temperature support.
      • 6: Fixed some bugs.
      UIFlow
      • world101W Offline
        world101
        Issues:
        • Screen rotation is now flipped upside down
        • When I select the Singapore server, the M5Stack won't connect in uiFlow. I'm in the US, so perhaps there is a connection issue from here. The China server still works.
        KentK 1 Reply Last reply Reply Quote 0
          jpilarski
          Always exciting to see new features added, is it possible to add the temp and humidity blocks you just released for the yun to the pm2.5.
          • OyczEO Offline
            OyczE @jpilarski
            @jpilarski said in UiFlow 1.4.3:
            https://github.com/m5stack/UiFlow-Bug-Report/issues/20
              chart function not working for the env sensor demo given in the UIFlow docs.
              • KentK Offline
                Kent @world101
                @world101 said in UiFlow 1.4.3:
                Issues:
                I meet this phenomenon too.
                M5Stack Basic (text "2017.6" on the board)
                UIFlow v1.32 and v1.42 are ok.
                • world101W Offline
                  world101 @Kent
                  @kent
                  Apparently the screen flip issue has been fixed...
                  link to twitter feed
                  I’ll update the firmware on M5burner tomorrow and test again.
                  • world101W Offline
                    world101
                    Looks like m5burner has been updated with the fixed 1.4.3 firmware. The screen is the correct orientation now. Just hit the X beside the firmware version, download it again, and reflash your m5stack.
                    • m5stackM Offline
                      we already fixed. pls delete the old firmware then download again.
                      • SkinkS Offline
                        Skink @m5stack
                        @m5stack
                        Hello, community,
                        when will the offline version of UI-Desktop 1.4.3 be available.
                        When will it be released !?
                        greeting skink
                        • m5stackM Offline
                          m5stack @Skink
                          @skink i have not idea , maybe later.......
                          • E Offline
                            Efried @m5stack
                            @m5stack ok, the new urequest implementation did cost me some time adapting the old code....
                            now also interruption of the wlan connection occurs more frequently, any improvements on that? Also I would need an example how to react to urequest failures via micropython try-catch, so far my code gest stuck.
