UIFlow Desktop can't connect to M5Stick
When i try to connect UIFlow Desktop (on Debian Linux) via USB to my M5Stick always this message appears:
Upload code failed, maybe your device is offline check it and retryand the statusbar shows
/dev/ttyUSB0[ Disconnected ]But the FirmwareBurner works well. Also i can use a serial connection (like
screen /dev/ttyUSB0 115200) to communicate successfull with my M5Stick (Micropython-REPL). So drivers are not the problem. I also tried this as root - same behavior..
Only the UIFlow connections to the USB isnt working.Of course I could use UIFlow online. In our school environment no internet connection is possible.
Thanks for your support
M5Stick? M5StickC? which product are you used ? UIFlow Desktop IDE don't support M5Stick. if you are using M5StickC, you should setup it the USB mode then , it can connect to the IDE.
tutorial :
https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow
Check out this video I did a while back on using M5Stack devices on linux https://www.youtube.com/watch?v=ZZdTl0400uM you need to make sure to add the device to the dialout group, I can't remember the exact line of code but it's in the video if you watch it
