    M5StickV Firmware_v5.1.2
    7 Posts 4 Posters 15.2k Views 2 Watching
    • m5stackM Online
      M5StickV Firmware_v5.1.2 Upgrade time : 2020.05.01
      log:
      • Optimize picture display
      Firmwae file Download links:
      https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/M5StickV_Firmware_v5.1.2.kfpkg
      Easyloader Download links (For Windows):
      https://m5stack.oss-cn-shenzhen.aliyuncs.com/EasyLoader/Windows/CORE/EasyLoader_M5StickV_v5.1.2.exe
        kalon33 @m5stack
        @m5stack I just updated my m5stickV from 4.0 version (factory version). Unfortunately, it won't power off anymore using long press on power button, only reset. Please fix.
          ajb2k3 @kalon33
          @kalon33 does it power off if you double press?
            kalon33 @ajb2k3
            @ajb2k3 No, it doesn't. So I have no way to power it off other than waiting for the battery to drain...
            • m5stackM Online
              m5stack @kalon33
              @kalon33 did you inserted SD card? the poweroff function need running in the boot program. if not it will disable. more information pls refer this link: https://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgrade
                kalon33 @m5stack
                @m5stack yes, and I'm running your v-training program when having this problem...
                  dclaar
                  I'm trying to do this update on windows:
                  But I get a window like this, while the S in a box flashes on the display:
                  [32m[INFO] COM Port Selected Manually:  COM7
                  [INFO] Default baudrate is 115200 , later it may be changed to the value you set.
                  [INFO] Trying to Enter the ISP Mode...
                  ._._._._._._._._._._._._._._._._._._._._
                  And then eventually "Failed" in the popup. I only get the one baudrate in the dialog, so I can't try to go slower. Any ideas on how I can make this go?
