    UIFlow 1.5.4
    23 Posts 7 Posters 78.2k Views 1 Watching
    • m5stackM Offline
      Ver 1.5.4 time : 2020.06.05
      UpdateLog:
      web:
      • Add: Unit AC Socket.
      • Add: Pin Servo.
      • Fixed some bugs.
      firmware:
      • Add: AC Socket support.
      • Add: Pin Servo support.
      • Update: unicode.
      • Fixed: title error.
      • Fixed some bugs.
      UIFlow1.5.4-ACSocket
        plusulli
        Pin Servo not working the USB port crashes and the M5stack Fire emits a sound
        • m5stackM Offline
          m5stack @plusulli
          @plusulli could provide more information about that? or share your program code to here. it will help us to find the problem
            plusulli @m5stack
            @m5stack Sorry today is all about me
            I don't know what I did wrong when I first tested it.
            • m5stackM Offline
              m5stack @plusulli
              @plusulli so it working normal right now?
                plusulli @m5stack
                @m5stack said in UIFlow 1.5.4:
                yes it works normal thank you for this function it is great
                  cortado
                  USB mode gone from Stick-C?? New "code" menu goes directly to Cloud mode. But in the cloud UI I cannot load blocklys from my computer. Is there a secret to enabling USB mode?
                  C lukasmaximusL 2 Replies Last reply Reply Quote 0
                    cortado @cortado
                    @cortado or maybe driver for MacOS needs update. Tried on my PC and could connect via the UART app :)
                      How do you use the AC socket as it an RS 485 device not a unit?
                      • m5stackM Offline
                        m5stack @ajb2k3
                        @ajb2k3 yeah. ACSocket is a RS485 slave device. you need use RS485 communication to control it.
                          @m5stack I'm trying to use the base26 rs485 adapter.
                            Ouu the new burner looks nice!
                            • OyczEO Offline
                              OyczE
                              Yep new Beta burner is great ! but got a bug with COM port refresh
                              Check this out, erased or burned one Lite then another was connected with diff COM but when i try to burn / erase there is old come exist.
                              text alternatywny
                              • m5stackM Offline
                                m5stack @OyczE
                                @mati thank you feedback. we will fix this bug as soon as possible
                                  sjako
                                  What's the latest stable (non beta) release of UIFlow, is that still 1.4.5? (When I download the version from https://m5stack.com/pages/download , I get 1.4.5)
                                  • m5stackM Offline
                                    m5stack @sjako
                                    @sjako you could select 1.4.5/1.5.4 two UIFlow version in the navigation right side.
                                      sjako @m5stack
                                      @m5stack Thanks, I found it, it was a bit hidden =)
                                      Maybe it should be a bit more clear 1.5.4 is a beta version? Maybe add a "b" after 1.5.4? Before I also tried the following option, but that's a completely different revision number
                                      • lukasmaximusL Offline
                                        lukasmaximus @cortado
                                        @cortado They changed the method to get into USB mode, which is a little tricky, press the left hand button on your stick-c to reset and then quickly press the button on the right side to enter usb mode, the usb symbol will appear if you are successful
                                        • m5stackM Offline
                                          m5stack @sjako
                                          @sjako in the check update page.the version number is desktop IDE software version.
                                            no hat and blocks for the rgb neoflash hat!
