@skink Thanks for your answer
How to recharge the battery
I just get my first M5StickC and I am wondering how to recharge the internal battery?
I try to connect to a USB IPhone 5v plug for 3 hours but I just get 5 minutes run time.
What do you recommend and how do you know when the battery is full?
Thanks in advance.
Failed to read register address
Hello
I just receive my M5Stack C, I went thru the install using Arduino but I always get an error during upload ( I run the Factory sketch test)"esptool.py v2.6
Serial port /dev/cu.usbserial-3D52321EB6
Connecting........___
Chip is ESP32-PICO-D4 (revision 1)A fatal error occurred: Failed to read register address 6001a00c (result was 01050000)
A fatal error occurred: Failed to read register address 6001a00c (result was 01050000)I use 115200 speed, ESP pico Kit as board, M5StickC library is install
Any advice please.
Thanks in advance
Jean-Claude
