@kawabatapaper Hi there! Can you please provide the program? and also every time the error occurs in about 9 hours?
RE: Error : can't create thread
RE: V-Training says "You must log in before uploading data"
@lagd sorry they will fix it in one week
RE: I want M5StickC can use BLE via Uiflow/microPython
@mrsteveman1 Hi there! I will forward your request to our technical support, thank you for letting us know!
RE: UHF-RFID-UNIT-JRD-4035 effective distance
@paopao Hi! If using UIFlow, then this is it, if it‘s Arduino. Serial port sending commands
or use API, then CH_index = 1
https://github.com/m5stack/M5Stack/blob/master/examples/Unit/UHF_RFID_JRD4035/RFID_command.cpp
RE: GPS - incorrect readings
@dsrc12 Hi! This must be outdoors in wide-open areas, cold start time takes about 3 / 4 minutes
RE: M5Stack core2 communicate with ROS
@lishengkkk Hi there, please check if the baud rate of both sides match (you can also try to change the baud rate, such as the common 115200). If it's a UART via separate wiring. Please make sure TX RX is connected correctly.
@k_hara Hi, We are fixing it! sorry for the inconvenience
@mpierce Hi, We are fixing it! sorry for the inconvenience
@lagd Hi, We are fixing it! sorry for the inconvenience
RE: Speaker.Volume on Core2
@hoodlem Hi! Thanks for the feedback! this is already on our lists! stay tuned for more
RE: core2 MBUS PIN for speaker output
@hoodlem Hi there! Core2 uses I2S digital power amplifier chip, which is different from Core1
RE: M5 AC Socket and M5 Light Socket
@glennswest Hi there, thanks for your feedback! we will be sure to let our innovation team know!
RE: Addressable I2C Switch
@glennswest Hi there! please have a look at https://docs.m5stack.com/en/unit/extio2
this supports software configuration of I2C address -
RE: M5-Stamp-Pico with I-PEX external antenna port
@chrismal Hi Good day! We appreciate your feedback!No IPEX version is available
RE: Use Atom RS485 as a data sniffer
Hi there We appreciate your feedback! but so far there is no demo provided
RE: Native support of the Edge Impulse for the M5Stack UnitV2 development board
Hi there we appreciate your feedback! we will share this with our team:) but no plan of it yet
RE: [PRODUCT] M5KNX Coupler Unit / Module
RE: vlearning login porblems
Hi there We appreciate your feedback! can u check one more time now
