    UIFlow 1.6.6
    16 Posts 10 Posters 31.5k Views 1 Watching
    • m5stackM Online
      UpdateLog:
      Ver 1.6.6 time : 2020.11.20
      new features
      * CoreInk support.
      Bug fix:
      * ESP-NOW bug fix.
      * BLE bug fix.
      * GoPlus 2 analog read bug fix.
      * Wi-Fi connect screen bug fix.
      UIFlowv1.6.6
        jesuslg123
        Hellos,
        That
        * BLE bug fix.
        mean bluetooth is now supported on UIFlow micropython firmware for M5StickC?
        If yes, could you shared a simple sample please?
        • OyczEO Offline
          OyczE
          Hey
          My coreInk is not able to Dowload the Test UI, run is working.
          After hit Download i have error in console
          [268314] MQTTException -> Server close socket link
          reconnect start ...
          sample app
          • L Offline
            lelehel
            Well, when I upload 1.6.6 to mey Core2, Blank screen. In the COM Monitor is see something like "Factory partition not Bootable"
            I tried many times, I erased the the memory before flashing. Nothing helps. :( 1.6.5.1 works fine.
            Should we wait for 1.7 to fix this issue? :)
            • felmueF Online
              Hi guys
              yes, UIFlow 1.6.6 firmware and M5Core2 is broken for me too. M5Core2 is connected to the UIFlow server - I can turn off and on the LED. But the display stays dark. I tried to set the LCD voltage and / or brightness level but that did not help. I assume the display is not properly initialised.
              BTW: UIFlow 1.6.6 firmware for M5StickC works fine.
              Update: fully powering down (long press power button or briefly removing the battery) restored my M5Core2 with UIFlow 1.6.6 firmware.
              • m5stackM Online
                m5stack @jesuslg123
                @jesuslg123 for the time being only for Fire & Core2
                W J 2 Replies Last reply Reply Quote 0
                • IAMLIUBOI Offline
                  IAMLIUBO @OyczE
                  @mati It's our server bug, fixed! Thanks for feedback.
                  • IAMLIUBOI Offline
                    IAMLIUBO @lelehel
                    @lelehel Hi, I test it, didn't see the problem like you say.Maybe you should remove the core2 firmware and download it again?If still have this problem just tell me!
                    • IAMLIUBOI Offline
                      IAMLIUBO @felmue
                      @felmue Good heard that!If you have any problem,just tell us!We will solve it at work day ASAP!
                      • W Offline
                        Wolli01 @m5stack
                        @m5stack said in UIFlow 1.6.6:
                          jesuslg123 @m5stack
                          @m5stack Thanks. Is there any plan for M5StickC?
                            Dario @jesuslg123
                            @jesuslg123 I'm using the version 1.6.6 with both StickC and SticC Plus without any issue
                              jesuslg123 @Dario
                              @dario said in UIFlow 1.6.6:
                              Are you using Bluetooth on StickC with 1.6.6? They mentioned Bluetooth is still not supported
                                Dario @jesuslg123
                                @jesuslg123 Sorry I misunderstood tha you were refering at the bluetooth on StickC and not at the at the firmware version. My bad.
                                No, I can't find the ubluetooth module on StickC
                                  dsrc12 @m5stack
                                  @m5stack I had problems downloading firmware updates for cores and drivers for the Arduino IDE over the last 5 days but today it all went well. All downloads worked and my test code on Fire also worked. I was able to download the latest version for Core Ink: 1.6.6.1 and it was able to connect and accept firmware from my Windows PC UIFlow IDE on-line (V1.6.6) but it would not execute any simple programs on Core Ink. It had problems with Core 2 and ended up abandoned it and completed my latest projects with Fire - it is a good stable platform and works with the latest firmware (1.6.6).
                                  • ZontexZ Offline
                                    Zontex @dsrc12
                                    @dsrc12 said in UIFlow 1.6.6:
                                    Have you tried repeating the process with UIFlow 1.4.5? is the issue only happens on 1.6.6 or also on 1.4.5? I will look into it to see what's going on.
