    Bug AtomS3 with UIFlow2 on library time
    15 Posts 3 Posters 16.0k Views 1 Watching
      flex @flex
      @flex on Alpha 10 the problem remains
        flex
        @flex said in Bug AtomS3 with UIFlow2 on library time:
        on Alpha 11 the problem remains
        • IAMLIUBOI Offline
          IAMLIUBO
          @flex
          Hi, did you check this time docs of micropython port?
            flex
            @imaliubo
            yes I tried,
            it seems that UIFlow (based on 1.19.1) doesn't take epoch into account, which is year 2000 in MP 1.19.1 or 1.20.
            Apart that there is confusion created on gmtime() and localtime() in UIFlow apis.
            Also to mention that in MP 1.20, the returned values from gmtime() and localtime() are not all time reliable (sometimes the ntpserver requested in MP localtime() return what in fact is gmtime()...)
              flex
              Hi dev Team,
              I made small test on Alpha17:
              • now "get UTC time" works correctly :)
              • There is problem when using "Set timezone GMTx":
                using "Set timezone GMT+2" and then "get local time", it should return UTC+2/GMT+2 but it return UTC-2/GMT-2
              • There is still problem with "get system uptime in seconds" which is not adjusted to epoch 2000 and returns a very big value
              IAMLIUBOI 2 Replies Last reply Reply Quote 0
              • IAMLIUBOI Offline
                IAMLIUBO @flex
                @flex
                honestly, I was confused at first, but i saw this link, it explain why the time zone is reversed:https://stackoverflow.com/questions/53076575/time-zones-etc-gmt-why-it-is-other-way-round
                ok, thanks for report, will check this and fix.
                • IAMLIUBOI Offline
                  IAMLIUBO @flex
                  @flex
                  Sorry, last update(aplha-17) we change the epoch time from "2000-01-01" ot "1970-01-01".So "get system uptime in seconds" block return is tiem stamp from 1970-01-01. And use "1970-01-01" as epoch is more compatible.
                    flex
                    I think that Micropython use epoch 2000 by default
                      @IAMLIUBO I'm getting an issue with time with 1.11.9 both the core and core 2 are showing an error with time "Module Time has no attribute"
                        flex @IAMLIUBO
                        @iamliubo
                        Hi
                        System uptime in seconds should return 0 when the system (m5stack ….S3) starts, nobostand epoch 1970 or 2000…
                        • IAMLIUBOI Offline
                          IAMLIUBO @flex
                          @flex yes, we change to 1970
                          • IAMLIUBOI Offline
                            IAMLIUBO @ajb2k3
                            @ajb2k3 can you show me the code?
                            • IAMLIUBOI Offline
                              IAMLIUBO @flex
                              @iamliubo
                              Hi
                              When boot up, if device connect to wifi will auto sync the time from ntp server, and time.time() this function will overwritten by new time.
                                ajb2k3 @IAMLIUBO
                                @iamliubo said in Bug AtomS3 with UIFlow2 on library time:
                                We solved it over Twitter
                                • K kimurer referenced this topic on
