    Bug AtomS3 with UIFlow2 on library time
    15 Posts 3 Posters 17.0k Views 1 Watching
      flex
      Hi dev Team,
      I made small test on Alpha17:
      • now "get UTC time" works correctly :)
      • There is problem when using "Set timezone GMTx":
        using "Set timezone GMT+2" and then "get local time", it should return UTC+2/GMT+2 but it return UTC-2/GMT-2
      • There is still problem with "get system uptime in seconds" which is not adjusted to epoch 2000 and returns a very big value
      IAMLIUBOI 2 Replies Last reply Reply Quote 0
      • IAMLIUBOI Offline
        IAMLIUBO @flex
        @flex
        honestly, I was confused at first, but i saw this link, it explain why the time zone is reversed:https://stackoverflow.com/questions/53076575/time-zones-etc-gmt-why-it-is-other-way-round
        ok, thanks for report, will check this and fix.
        • IAMLIUBOI Offline
          IAMLIUBO @flex
          @flex
          Sorry, last update(aplha-17) we change the epoch time from "2000-01-01" ot "1970-01-01".So "get system uptime in seconds" block return is tiem stamp from 1970-01-01. And use "1970-01-01" as epoch is more compatible.
            flex
            I think that Micropython use epoch 2000 by default
              @IAMLIUBO I'm getting an issue with time with 1.11.9 both the core and core 2 are showing an error with time "Module Time has no attribute"
                flex @IAMLIUBO
                @iamliubo
                Hi
                System uptime in seconds should return 0 when the system (m5stack ….S3) starts, nobostand epoch 1970 or 2000…
                • IAMLIUBOI Offline
                  IAMLIUBO @flex
                  @flex yes, we change to 1970
                  • IAMLIUBOI Offline
                    IAMLIUBO @ajb2k3
                    @ajb2k3 can you show me the code?
                    • IAMLIUBOI Offline
                      IAMLIUBO @flex
                      @flex said in Bug AtomS3 with UIFlow2 on library time:
                      @iamliubo
                      Hi
                      When boot up, if device connect to wifi will auto sync the time from ntp server, and time.time() this function will overwritten by new time.
                        ajb2k3 @IAMLIUBO
                        @iamliubo said in Bug AtomS3 with UIFlow2 on library time:
                        We solved it over Twitter
                        • K kimurer referenced this topic on
