    cardputer stuck on develop
    24 Posts 8 Posters 24.2k Views 2 Watching
      ajb2k3 @ToxicAvenger
      @toxicavenger UIflow 2 was updated a few weeks back but the engineers have been on tour
      I am in the process of uploading a series of videos on installing UIFlow2 on YouTube
        ToxicAvenger @ajb2k3
        @ajb2k3 whats your youtube and are you doing a video on how I can fix this issue, also when will your video be put on?
          https://youtu.be/bnw0tPslV2o?si=jE61HjFvSB90atxy
            @ajb2k3 -chip auto --port COM6 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x9000 C:\Users\lemstudent\Desktop\M5Burner-v3-beta-win-x64\packages\tmp\uiflow2-cfg.bin
            esptool.py v4.6.2
            Serial port COM6
            A fatal error occurred: Could not open COM6, the port doesn't exist
            This is what i get when I try to
              ToxicAvenger
              When i reset it says com 5 then com 6 then
              --chip auto --port COM6 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x9000 C:\Users\lemstudent\Desktop\M5Burner-v3-beta-win-x64\packages\tmp\uiflow2-cfg.bin
              esptool.py v4.6.2
              Serial port COM6
              Connecting...
              A fatal error occurred: Failed to connect to Espressif device: No serial data received.
              For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
              • robskiR Offline
                robski @ToxicAvenger
                @toxicavenger said in cardputer stuck on develop:
                esptool.py v4.6.2
                Serial port COM6
                Connecting...
                try to press and hold boot button for few seconds while plugging in usb to it .....and keep on/off in off position so m5stamp is powered up from usb not from battery
                  Try different cables. Not all cables are the same and some USBC cables don’t appear to work.
                    ToxicAvenger
                    @ajb2k3 tried 4 different data cables, still same result. Do you think its defective or is it me?
                      Does Windows show any errors with the Com port?
                        @ajb2k3 when I do the reset with go and reset button before trying to burn it pops up a window show port5 then another saying port6. When I do anything after that it only gives option for port6 and nothing works on it
                          Does windows hardware manager or what ever its called show an error with the ports?
                          • RuelvilloR Offline
                            Ruelvillo
                            When in doubt, G0 and RST it out, hold G0 and tap RST and then let go of G0.
                            • W Offline
                              wilsoreal
                              has anyone found a solution, i am having the same problem
                                @wilsoreal said in cardputer stuck on develop:
                                Have you watched the video I linked to above?
                                • W Offline
                                  wilsoreal @ajb2k3
                                  @ajb2k3 yea but still cant erase my sd and when i try to navigate anything in UI flow 2 it just doesnt work
                                    ROLF_STEINER
                                    hi guys!!! same thing here too....
                                    I used multiple cables (no result)
                                    I updated softwares like a collector in a bunch of them...(same results)...
                                    im absolutely lost....
                                    so if someone see the light please share the trick...0_1715919681849_49fe5e9d-cbe7-4bf7-a20b-41c468144631-Captura de pantalla 2024-05-17 a las 00.16.41.png Captura de pantalla 2024-05-17 a las 00.16.41
                                    Captura de pantalla 2024-05-17 a las 00.16.54
                                    Captura de pantalla 2024-05-17 a las 00.17.05
                                    Captura de pantalla 2024-05-17 a las 00.19.24
                                      ROLF_STEINER @ROLF_STEINER
                                      @rolf_steiner 0_1715919754111_e65ec64d-476a-4348-b3ba-5aa2e8278b4b-Captura de pantalla 2024-05-17 a las 00.16.41.png Captura de pantalla 2024-05-17 a las 00.16.41
                                      0_1715919776087_d7f2a03d-e560-4cd2-8112-b037947185cb-Captura de pantalla 2024-05-17 a las 00.16.54.png Captura de pantalla 2024-05-17 a las 00.16.54
                                      0_1715919798187_0042aa19-4ca4-42d3-9ac9-49e45cb656d8-Captura de pantalla 2024-05-17 a las 00.17.05.png Captura de pantalla 2024-05-17 a las 00.17.05
                                      0_1715919817648_d392fe34-7bc3-41fa-a53c-753f7b2bfd19-Captura de pantalla 2024-05-17 a las 00.19.24.png Captura de pantalla 2024-05-17 a las 00.19.24
                                        Have you installed ESP-IDF?
                                          ROLF_STEINER @ajb2k3
                                          @ajb2k3 sure mate, after all, I redo all my steps and following the youtube video finally works.
                                          many thanks and tons of likes!!
                                            mnhj @ToxicAvenger
                                            @ToxicAvenger hi i got a new core s3 and was not aware of this boot mode and the error was also occoring to me but on sync screen but on the core s3 to fix it i have to hold the reset button until ther green light turns on then only it started to upload new uiflow so for the cardputer it might be the same problem and also try using a diffrent usb cable.I was using wifi upload and it crashed during sync
                                            software info and hardware
                                            board : m5stack core s3
                                            MCU : esp32s3 extenza lx7
                                            uiflow vertion : 2.0.7
                                            arduino ver : 2.1.0
                                            windows 10
