    69 Posts 7 Posters 435.9k Views 1 Watching
      ajb2k3 @m5-docs
      @watson I can't use the M5burner of the Stick C as it it coming up as
      Port: "dev/cu.serial-6D52F9B441
      instead of the expected
      Port: "dev/cu.SLAB_USBtoUART
      • m5-docsM Offline
        m5-docs @ajb2k3
        @ajb2k3 Are you working with Mac OS?
        M5Stack documentation URL
        https://docs.m5stack.com
          ajb2k3 @m5-docs
          @watson
          Yes, but is only the StickC that is giving the strange port ID.
          All others report normal port.
          • m5-docsM Offline
            m5-docs @GACHAPO
            @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
              salty_good
              I understood this problem.
              We need to fix M5Burner for mac.
                ajb2k3 @salty_good
                @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                Can you add drop down box to select port?
                ポートを選択するためのドロップダウンボックスを追加できますか?
                • m5-docsM Offline
                  m5-docs @GACHAPO
                    salty_good @ajb2k3
                    @ajb2k3 Off course yes,
                    and Baudrate also needs to be selectable.
                    • G Offline
                      GACHAPO @m5-docs
                      @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
                      • m5-docsM Offline
                        m5-docs @GACHAPO
                        Hello @gachapo It's best to use esp-idf.
                        • G Offline
                          GACHAPO @m5-docs
                          @watson Thanks- can you use arduino-ide?
                          • m5-docsM Offline
                            m5-docs @GACHAPO
                            Hello @gachapo,
                            Yes, Color recognition arduino program may help you.
                            Here's the code:
                            https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
                            • G Offline
                              GACHAPO @m5-docs
                              @watson Thank you.
                              Do I choose CAMERA_MODEL_WROVER_KIT?
                              • m5-docsM Offline
                                m5-docs @GACHAPO
                                @gachapo
                                You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
                                // Select camera model
                                //#define CAMERA_MODEL_WROVER_KIT
                                #define CAMERA_A_MODEL_M5STACK_PSRAM
                                //#define CAMERA_MODEL_AI_THINKER
                                • m5-docsM Offline
                                  m5-docs
                                  @GACHAPO @ajb2k3 Thanks your support
                                  • G Offline
                                    GACHAPO @m5-docs
                                    @watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
                                    • m5-docsM Offline
                                      m5-docs @GACHAPO
                                      @gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
                                      https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62
                                      #elif defined(CAMERA_A_MODEL_M5STACK_PSRAM)
                                      #define PWDN_GPIO_NUM     -1
                                      #define RESET_GPIO_NUM    15
                                      #define XCLK_GPIO_NUM     27
                                      #define SIOD_GPIO_NUM     25
                                      #define SIOC_GPIO_NUM     23
                                      #define Y9_GPIO_NUM       19
                                      #define Y8_GPIO_NUM       36
                                      #define Y7_GPIO_NUM       18
                                      #define Y6_GPIO_NUM       39
                                      #define Y5_GPIO_NUM        5
                                      #define Y4_GPIO_NUM       34
                                      #define Y3_GPIO_NUM       35
                                      #define Y2_GPIO_NUM       32
                                      #define VSYNC_GPIO_NUM    22
                                      #define HREF_GPIO_NUM     26
                                      #define PCLK_GPIO_NUM     21
                                      • G Offline
                                        GACHAPO
                                        Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
                                        • m5-docsM Offline
                                          m5-docs @GACHAPO
                                          @gachapo
                                          • G Offline
                                            GACHAPO
                                            Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
