    69 Posts 7 Posters 435.9k Views 1 Watching
    • G Offline
      GACHAPO
      That's great thank you - works.
      Is there any documentation about how to assign your own IP address to the camera please?
      • m5-docsM Offline
        m5-docs @GACHAPO
        @gachapo Do you mean this doc?
        https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
        M5Stack documentation URL
        • G Offline
          GACHAPO
          I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
            ajb2k3 @GACHAPO
            @gachapo you need to recompile the code is ST mode and upload to cameea
            • G Offline
              GACHAPO @ajb2k3
              @ajb2k3 Thanks - Is there any documentation you can point me to please?
                ajb2k3 @GACHAPO
                • m5-docsM Offline
                  m5-docs @GACHAPO
                  @gachapo At main.c file
                  • G Offline
                    GACHAPO
                    Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
                    • m5-docsM Offline
                      m5-docs @GACHAPO
                      @gachapo
                      Download the firmware of ESP32CAM
                      • G Offline
                        GACHAPO
                        ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
                          ajb2k3 @m5-docs
                          @watson I can't use the M5burner of the Stick C as it it coming up as
                          Port: "dev/cu.serial-6D52F9B441
                          instead of the expected
                          Port: "dev/cu.SLAB_USBtoUART
                          • m5-docsM Offline
                            m5-docs @ajb2k3
                            @ajb2k3 Are you working with Mac OS?
                              ajb2k3 @m5-docs
                              @watson
                              Yes, but is only the StickC that is giving the strange port ID.
                              All others report normal port.
                              • m5-docsM Offline
                                m5-docs @GACHAPO
                                @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                                  salty_good
                                  I understood this problem.
                                  We need to fix M5Burner for mac.
                                    ajb2k3 @salty_good
                                    @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                                    Can you add drop down box to select port?
                                    ポートを選択するためのドロップダウンボックスを追加できますか?
                                    • m5-docsM Offline
                                      m5-docs @GACHAPO
                                        salty_good @ajb2k3
                                        @ajb2k3 Off course yes,
                                        and Baudrate also needs to be selectable.
                                        • G Offline
                                          GACHAPO @m5-docs
                                          @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
                                          • m5-docsM Offline
                                            m5-docs @GACHAPO
                                            Hello @gachapo It's best to use esp-idf.
