    69 Posts 7 Posters 435.9k Views 1 Watching
    • G Offline
      GACHAPO @ajb2k3
      @ajb2k3 Thanks - Is there any documentation you can point me to please?
        ajb2k3 @GACHAPO
        • m5-docsM Offline
          m5-docs @GACHAPO
          @gachapo At main.c file
          M5Stack documentation URL
          https://docs.m5stack.com
          • G Offline
            GACHAPO
            Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
            • m5-docsM Offline
              m5-docs @GACHAPO
              @gachapo
              Download the firmware of ESP32CAM
              • G Offline
                GACHAPO
                ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
                  ajb2k3 @m5-docs
                  @watson I can't use the M5burner of the Stick C as it it coming up as
                  Port: "dev/cu.serial-6D52F9B441
                  instead of the expected
                  Port: "dev/cu.SLAB_USBtoUART
                  • m5-docsM Offline
                    m5-docs @ajb2k3
                    @ajb2k3 Are you working with Mac OS?
                      ajb2k3 @m5-docs
                      @watson
                      Yes, but is only the StickC that is giving the strange port ID.
                      All others report normal port.
                      • m5-docsM Offline
                        m5-docs @GACHAPO
                        @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                          salty_good
                          I understood this problem.
                          We need to fix M5Burner for mac.
                            ajb2k3 @salty_good
                            @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                            Can you add drop down box to select port?
                            ポートを選択するためのドロップダウンボックスを追加できますか?
                            • m5-docsM Offline
                              m5-docs @GACHAPO
                                salty_good @ajb2k3
                                @ajb2k3 Off course yes,
                                and Baudrate also needs to be selectable.
                                • G Offline
                                  GACHAPO @m5-docs
                                  @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
                                  • m5-docsM Offline
                                    m5-docs @GACHAPO
                                    Hello @gachapo It's best to use esp-idf.
                                    • G Offline
                                      GACHAPO @m5-docs
                                      @watson Thanks- can you use arduino-ide?
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                        Hello @gachapo,
                                        Yes, Color recognition arduino program may help you.
                                        Here's the code:
                                        https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
                                        • G Offline
                                          GACHAPO @m5-docs
                                          @watson Thank you.
                                          Do I choose CAMERA_MODEL_WROVER_KIT?
                                          • m5-docsM Offline
                                            m5-docs @GACHAPO
                                            @gachapo
                                            You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
                                            // Select camera model
                                            //#define CAMERA_MODEL_WROVER_KIT
                                            #define CAMERA_A_MODEL_M5STACK_PSRAM
                                            //#define CAMERA_MODEL_AI_THINKER
