    69 Posts 7 Posters 435.9k Views 1 Watching
    • m5-docsM Offline
      m5-docs @GACHAPO
      @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
      Here's the doc for it.
      M5Stack documentation URL
      • G Offline
        GACHAPO
        That's great thank you - works.
        Is there any documentation about how to assign your own IP address to the camera please?
        • m5-docsM Offline
          m5-docs @GACHAPO
          @gachapo Do you mean this doc?
          https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
          • G Offline
            GACHAPO
            I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
              ajb2k3 @GACHAPO
              @gachapo you need to recompile the code is ST mode and upload to cameea
              • G Offline
                GACHAPO @ajb2k3
                @ajb2k3 Thanks - Is there any documentation you can point me to please?
                  ajb2k3 @GACHAPO
                  • m5-docsM Offline
                    m5-docs @GACHAPO
                    @gachapo At main.c file
                    • G Offline
                      GACHAPO
                      Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
                      • m5-docsM Offline
                        m5-docs @GACHAPO
                        @gachapo
                        Download the firmware of ESP32CAM
                        • G Offline
                          GACHAPO
                          ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
                            ajb2k3 @m5-docs
                            @watson I can't use the M5burner of the Stick C as it it coming up as
                            Port: "dev/cu.serial-6D52F9B441
                            instead of the expected
                            Port: "dev/cu.SLAB_USBtoUART
                            • m5-docsM Offline
                              m5-docs @ajb2k3
                              @ajb2k3 Are you working with Mac OS?
                                ajb2k3 @m5-docs
                                @watson
                                Yes, but is only the StickC that is giving the strange port ID.
                                All others report normal port.
                                • m5-docsM Offline
                                  m5-docs @GACHAPO
                                  @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                                    salty_good
                                    I understood this problem.
                                    We need to fix M5Burner for mac.
                                      ajb2k3 @salty_good
                                      @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                                      Can you add drop down box to select port?
                                      ポートを選択するためのドロップダウンボックスを追加できますか?
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                          salty_good @ajb2k3
                                          @ajb2k3 Off course yes,
                                          and Baudrate also needs to be selectable.
                                          • G Offline
                                            GACHAPO @m5-docs
                                            @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
