    About Hat 8servos
    11 Posts 3 Posters 21.5k Views 1 Watching
      coffeeworm
      I trying m5stickC+Hat 8servos, when I use UiFlow blocky code, it not work!
      But I use arduino code, it work.
      UiFlow version is 1.4.2
        Can you share a screen shot of you UIFlow code please?
          coffeeworm
            coffeeworm
            I record a mp4 video. The RGB worked but Servo not.
            https://youtu.be/iymi3ziUE7M
              if you put pressure on the servo horn, does the horn move?
                coffeeworm
                @ajb2k3 said in About Hat 8servos:
                pressure
                When the program is executed, the pressure on the servo horn is rotatable.
                X ajb2k3A 2 Replies Last reply Reply Quote 0
                • X Offline
                  Xeon @coffeeworm
                  @coffeeworm
                  Sounds like your not getting power.
                  The war of 1 and 0 draws ever closer.
                  everyday i work to become a cyborg.
                    ajb2k3 @coffeeworm
                    @coffeeworm said in About Hat 8servos:
                    pressure
                    as @Xeon replied, you dont have power to the servos. is the power switch in the correct position?
                      coffeeworm
                      Yes,the power is switch in the correct position.
                      I am sure that it is not a power problem.
                        coffeeworm
                        I found a solution, I have to set it up first, then the servo can work.
                        Thank you for your response.
                          Ah, that is worth Knowing thanks.
                          I haven't got one yet so didn't know that they needed a "Initial Position" set up.
                          Thank you for working this out.
