๐Ÿค–Have you ever tried Chat.M5Stack.com before asking??๐Ÿ˜Ž
    M5StickC usb driver and Catalina
    30 Posts 12 Posters 128.9k Views 2 Watching
      sheepDog @flippycurb
      In the meantime I tested three M5StickC and can not program anyone without "Connect G0 pin to GND". I changed from Arduino to esp-idf and got the same issue.
      After some analysis, I separated the problem: I think the esptool.py didn't work correct with the cp210x drivers. The critical part is:
        def _connect_attempt(self, mode='default_reset', esp32r0_delay=False):
          """ A single connection attempt, with esp32r0 workaround options """
          # esp32r0_delay is a workaround for bugs with the most common auto reset
          # circuit and Windows, if the EN pin on the dev board does not have
          # enough capacitance.
          # Newer dev boards shouldn't have this problem (higher value capacitor
          # on the EN pin), and ESP32 revision 1 can't use this workaround as it
          # relies on a silicon bug.
          # Details: https://github.com/espressif/esptool/issues/136
          last_error = None
          # If we're doing no_sync, we're likely communicating as a pass through
          # with an intermediate device to the ESP32
          if mode == "no_reset_no_sync":
              return last_error
          # issue reset-to-bootloader:
          # RTS = either CH_PD/EN or nRESET (both active low = chip in reset
          # DTR = GPIO0 (active low = boot to flasher)
          # DTR & RTS are active low signals,
          # ie True = pin @ 0V, False = pin @ VCC.
          if mode != 'no_reset':
              self._setDTR(False)  # IO0=HIGH
              self._setRTS(True)   # EN=LOW, chip in reset
              time.sleep(0.1)
              if esp32r0_delay:
                  # Some chips are more likely to trigger the esp32r0
                  # watchdog reset silicon bug if they're held with EN=LOW
                  # for a longer period
                  time.sleep(1.2)
              self._setDTR(True)   # IO0=LOW
              self._setRTS(False)  # EN=HIGH, chip out of reset
              if esp32r0_delay:
                  # Sleep longer after reset.
                  # This workaround only works on revision 0 ESP32 chips,
                  # it exploits a silicon bug spurious watchdog reset.
                  time.sleep(0.4)  # allow watchdog reset to occur
              time.sleep(0.05)
              self._setDTR(False)  # IO0=HIGH, done
          for _ in range(5):
              try:
                  self.flush_input()
                  self._port.flushOutput()
                  self.sync()
                  return None
              except FatalError as e:
                  if esp32r0_delay:
                      print('_', end='')
                  else:
                      print('.', end='')
                  sys.stdout.flush()
                  time.sleep(0.05)
                  last_error = e
          return last_error
      def connect(self, mode='default_reset'):
          """ Try connecting repeatedly until successful, or giving up """
          print('Connecting...', end='')
          sys.stdout.flush()
          last_error = None
          try:
              for _ in range(7):
                  last_error = self._connect_attempt(mode=mode, esp32r0_delay=False)
                  if last_error is None:
                      return
                  last_error = self._connect_attempt(mode=mode, esp32r0_delay=True)
                      return
          finally:
              print('')  # end 'Connecting...' line
          raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
      The esptool.py used reset with DTR and RTS and I suspect this part did not work correct, because any print of '.' or '_' showed a (fatal) error.
      My short test for all existing ports showed the error:
      $IDF_PATH/components/esptool_py/esptool/esptool.py chip_id
      • m5stackM Online
        m5stack @sheepDog
        @sheepdog this problem from MAC OS FTDI driver , you can try to use WIN10 OS (like using a virtual machine) to upload program. also M5StickC Upload program don't need CP2104 Driver.
          sheepDog @m5stack
          @m5stack Thank you for your quick response. I am sure that Mac OS Catalina need a driver. A few days ago I installed Mac OS 10.15.2 form scratch and M5StickC needs the cp210x-driver (M5Stack needs the FTDI driver!).
          You can test it. If you connect a M5StickC you see at the directory /dev a file with this name "cu.usbserial-<number>". With connected M5Stack you see "cu.SLAB_USBtoUART" (<- This is the FTDI driver).
          My workaround is "Connect G0 pin to GND". That is not nice. Your solution to start a VM is even more complex because all need all my files there.
          Yes, I can program M5StickC, but I am looking for an easy way to program M5StickC with short turn around times and easy handling. Normally I used Atom editor with PlatformIO.
            tcruse
            @m5stack could you please advise on the best process for getting M5StickC to work and flash via esptool on Mac OS Catalina ?
            Also, advise on which driver is needed for M5StickC. Is it the FTDI driver or is it the CP210X driver ?
            • m5stackM Online
              m5stack @tcruse
              @tcruse first , on some Mac PC, M5StickC cannot upload program properly.
              the solution: When programming, short the G0 to GND using the DuPont line.
              and , all most PC don't need driver with M5StickC. But some old PC System need install FTDI driver.
              FTDI driver is for M5StickC, CP2104 driver is for M5Stack Core ( like Fire BASIC M5GO)
                sheepDog @m5stack
                @m5stack Yes, I swapped the drivers. You can check it at Apple menu, systemreport and USB.
                1. If I connected a M5Stack I saw:
                2. If I connected a M5StickC I saw:
                You can check the loaded drivers and their versions in terminal with "sudo kextstat".
                I noticed that sometimes M5Stack didn't not work without "short the G0 to GND". I think that is a timing-problem at Catalina and esptool.py. It is not a problem of M5Stack- or M5StickC-Software.
                  sheepDog
                  I formulated an Issue at Github: Link to Issue
                  Supplement on January 18, 2020: You need an Espressif account to see the issue.
                  • m5stackM Online
                    m5stack @sheepDog
                    D S 2 Replies Last reply Reply Quote 0
                      diogovaraujo @m5stack
                      @m5stack Cant click that link.
                        sheepDog @m5stack
                        @m5stack
                        I got this error if I click your link: "Access denied. You do not have permission to access this page."
                        Thank you for updating your software.
                        • world101W Offline
                          world101
                          The link worked for me once a few hours ago, but now itโ€™s not.
                          • N Offline
                            nsfilho @o.copleston
                            @o-copleston This solution is running perfectly! Thank you!
                            • m5stackM Online
                              m5stack @diogovaraujo
                              It may make your firmware lose and make it unusable, so if you are willing to take this risk, you can chat with me in private and I will give you a link to download the tool @sheepDog @world101
                                sheepDog @m5stack
                                @m5stack Hello, are there any news about a solution for Catalina and M5StickC?
                                • N Offline
                                  nsfilho @sheepDog
                                  @m5stack if you can, please give us the link for a new driver to solve that problem....
                                  • m5stackM Online
                                    m5stack @nsfilho
                                    @nsfilho @sheepDog Please read the information carefully before using the tool
                                    link:
                                    http://community.m5stack.com/topic/1591/m5stickc-and-atom-on-macos-platform-can-t-upload-programs-solustion
                                    • N Offline
                                      nsfilho @m5stack
                                      @m5stack Thank you! The solution 2 (as describe in link) is fully functional.
                                      With your input, this post could be even better ๐Ÿ’—
