    M5StickC usb driver and Catalina
    30 Posts 12 Posters 128.9k Views 2 Watching
      tcruse
      @m5stack could you please advise on the best process for getting M5StickC to work and flash via esptool on Mac OS Catalina ?
      Also, advise on which driver is needed for M5StickC. Is it the FTDI driver or is it the CP210X driver ?
      • m5stackM Online
        m5stack @tcruse
        @tcruse first , on some Mac PC, M5StickC cannot upload program properly.
        the solution: When programming, short the G0 to GND using the DuPont line.
        and , all most PC don't need driver with M5StickC. But some old PC System need install FTDI driver.
        FTDI driver is for M5StickC, CP2104 driver is for M5Stack Core ( like Fire BASIC M5GO)
          sheepDog @m5stack
          @m5stack Yes, I swapped the drivers. You can check it at Apple menu, systemreport and USB.
          1. If I connected a M5Stack I saw:
          2. If I connected a M5StickC I saw:
          You can check the loaded drivers and their versions in terminal with "sudo kextstat".
          I noticed that sometimes M5Stack didn't not work without "short the G0 to GND". I think that is a timing-problem at Catalina and esptool.py. It is not a problem of M5Stack- or M5StickC-Software.
            sheepDog
            I formulated an Issue at Github: Link to Issue
            Supplement on January 18, 2020: You need an Espressif account to see the issue.
            • m5stackM Online
              m5stack @sheepDog
              D S 2 Replies Last reply Reply Quote 0
                diogovaraujo @m5stack
                @m5stack Cant click that link.
                  sheepDog @m5stack
                  @m5stack
                  I got this error if I click your link: "Access denied. You do not have permission to access this page."
                  Thank you for updating your software.
                  • world101W Offline
                    world101
                    The link worked for me once a few hours ago, but now it’s not.
                    • N Offline
                      nsfilho @o.copleston
                      @o-copleston This solution is running perfectly! Thank you!
                      • m5stackM Online
                        m5stack @diogovaraujo
                        It may make your firmware lose and make it unusable, so if you are willing to take this risk, you can chat with me in private and I will give you a link to download the tool @sheepDog @world101
                          sheepDog @m5stack
                          @m5stack Hello, are there any news about a solution for Catalina and M5StickC?
                          • N Offline
                            nsfilho @sheepDog
                            @m5stack if you can, please give us the link for a new driver to solve that problem....
                            • m5stackM Online
                              m5stack @nsfilho
                              @nsfilho @sheepDog Please read the information carefully before using the tool
                              link:
                              http://community.m5stack.com/topic/1591/m5stickc-and-atom-on-macos-platform-can-t-upload-programs-solustion
                              • N Offline
                                nsfilho @m5stack
                                @m5stack Thank you! The solution 2 (as describe in link) is fully functional.
