    69 Posts 7 Posters 428.3k Views 1 Watching
    • G Offline
      GACHAPO
      **M5 Burner Firmware Option Update **
      New to all of this so please treat me kindly.
      I have downloaded the M5 Burner, but the only firmware options I have is for the stick. I need the M5 Cam firmware. Can anybody please advise?
        which os are you on?
        OSX - http://flow.m5stack.com/download/M5Burner_MacOS.zip
        Windows - https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/software/M5Burner.zip
        • G Offline
          GACHAPO
          Windows 10.
          Never loads any other versions of firmware other than the ones listed above.
            ajb2k3 @GACHAPO
            @gachapo
            the windows link i posted is the uiflow firmware loader but it has the camera firmware in the package.
            • G Offline
              GACHAPO
              Thanks for coming back to me.
              So which one do I choose please?
                For the MK1 (no case) use cam0.02
                For the MK2 with PSRam use M5Cam-psram
                I do believe the fisheye also uses the M5Cam-psram firmware.
                • G Offline
                  GACHAPO
                  This is my camera;
                  I have UIFLow-v 1.2.3-en loaded and I have setup an IP address but nothing is loading.
                  The options I have are on the image I loaded - I see no cam0.02?
                    ajb2k3 @GACHAPO
                    @gachapo There should be an option in the top dropdown box to select it.
                    alt text
                    Click on the box next to firmware
                      Click on the M5Flow-v1.2.1-en and a box will drop down, scroll through the list and the cam firmware is near the top.
                      • G Offline
                        GACHAPO
                        That's my point - there's nothing more than the image I sent.
                        The only choices I have are on the left and the only drop down boxes are at the top and relate to the COM port and Baud rate??
                          ajb2k3 @GACHAPO
                          @gachapo said in M5 Burner Firmware Option Update:
                          Sorry No image has appeared.
                          • G Offline
                            GACHAPO
                              ajb2k3 @GACHAPO
                              Um, something is not quite correct there!
                              @watson
                                An alternative is that you can download the source code and compile it yourself.
                                • G Offline
                                  GACHAPO
                                  I could, if I knew how.
                                  I was hoping somebody would know why I cant use the burner?
                                  • m5-docsM Offline
                                    m5-docs
                                    Hello @GACHAPO @ajb2k3,
                                    Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
                                    M5Stack documentation URL
                                    https://docs.m5stack.com
                                    • G Offline
                                      GACHAPO @m5-docs
                                      @watson Thanks for coming back to me.
                                      I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                        @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
                                        Here's the doc for it.
                                        • G Offline
                                          GACHAPO
                                          That's great thank you - works.
                                          Is there any documentation about how to assign your own IP address to the camera please?
                                          • m5-docsM Offline
                                            m5-docs @GACHAPO
                                            @gachapo Do you mean this doc?
                                            https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
