    69 Posts 7 Posters 435.9k Views 1 Watching
    • G Offline
      GACHAPO
      Thanks for coming back to me.
      So which one do I choose please?
        For the MK1 (no case) use cam0.02
        For the MK2 with PSRam use M5Cam-psram
        I do believe the fisheye also uses the M5Cam-psram firmware.
        • G Offline
          GACHAPO
          This is my camera;
          I have UIFLow-v 1.2.3-en loaded and I have setup an IP address but nothing is loading.
          The options I have are on the image I loaded - I see no cam0.02?
            ajb2k3 @GACHAPO
            @gachapo There should be an option in the top dropdown box to select it.
            alt text
            Click on the box next to firmware
              Click on the M5Flow-v1.2.1-en and a box will drop down, scroll through the list and the cam firmware is near the top.
              • G Offline
                GACHAPO
                That's my point - there's nothing more than the image I sent.
                The only choices I have are on the left and the only drop down boxes are at the top and relate to the COM port and Baud rate??
                  ajb2k3 @GACHAPO
                  @gachapo said in M5 Burner Firmware Option Update:
                  Sorry No image has appeared.
                  • G Offline
                    GACHAPO
                      ajb2k3 @GACHAPO
                      Um, something is not quite correct there!
                      @watson
                        An alternative is that you can download the source code and compile it yourself.
                        • G Offline
                          GACHAPO
                          I could, if I knew how.
                          I was hoping somebody would know why I cant use the burner?
                          • m5-docsM Offline
                            m5-docs
                            Hello @GACHAPO @ajb2k3,
                            Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
                            M5Stack documentation URL
                            https://docs.m5stack.com
                            • G Offline
                              GACHAPO @m5-docs
                              @watson Thanks for coming back to me.
                              I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
                              • m5-docsM Offline
                                m5-docs @GACHAPO
                                @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
                                Here's the doc for it.
                                • G Offline
                                  GACHAPO
                                  That's great thank you - works.
                                  Is there any documentation about how to assign your own IP address to the camera please?
                                  • m5-docsM Offline
                                    m5-docs @GACHAPO
                                    @gachapo Do you mean this doc?
                                    https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
                                    • G Offline
                                      GACHAPO
                                      I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                                        ajb2k3 @GACHAPO
                                        @gachapo you need to recompile the code is ST mode and upload to cameea
                                        • G Offline
                                          GACHAPO @ajb2k3
                                          @ajb2k3 Thanks - Is there any documentation you can point me to please?
                                            ajb2k3 @GACHAPO
