    69 Posts 7 Posters 435.9k Views 1 Watching
      ajb2k3 @GACHAPO
      @gachapo There should be an option in the top dropdown box to select it.
      alt text
      Click on the box next to firmware
        Click on the M5Flow-v1.2.1-en and a box will drop down, scroll through the list and the cam firmware is near the top.
        • G Offline
          GACHAPO
          That's my point - there's nothing more than the image I sent.
          The only choices I have are on the left and the only drop down boxes are at the top and relate to the COM port and Baud rate??
            ajb2k3 @GACHAPO
            @gachapo said in M5 Burner Firmware Option Update:
            Sorry No image has appeared.
            • G Offline
              GACHAPO
                ajb2k3 @GACHAPO
                Um, something is not quite correct there!
                @watson
                  An alternative is that you can download the source code and compile it yourself.
                  • G Offline
                    GACHAPO
                    I could, if I knew how.
                    I was hoping somebody would know why I cant use the burner?
                    • m5-docsM Offline
                      m5-docs
                      Hello @GACHAPO @ajb2k3,
                      Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
                      M5Stack documentation URL
                      https://docs.m5stack.com
                      • G Offline
                        GACHAPO @m5-docs
                        @watson Thanks for coming back to me.
                        I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
                        • m5-docsM Offline
                          m5-docs @GACHAPO
                          @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
                          Here's the doc for it.
                          • G Offline
                            GACHAPO
                            That's great thank you - works.
                            Is there any documentation about how to assign your own IP address to the camera please?
                            • m5-docsM Offline
                              m5-docs @GACHAPO
                              @gachapo Do you mean this doc?
                              https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
                              • G Offline
                                GACHAPO
                                I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                                  ajb2k3 @GACHAPO
                                  @gachapo you need to recompile the code is ST mode and upload to cameea
                                  • G Offline
                                    GACHAPO @ajb2k3
                                    @ajb2k3 Thanks - Is there any documentation you can point me to please?
                                      ajb2k3 @GACHAPO
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                        @gachapo At main.c file
                                        • G Offline
                                          GACHAPO
                                          Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
                                          • m5-docsM Offline
                                            m5-docs @GACHAPO
                                            @gachapo
                                            Download the firmware of ESP32CAM
