    69 Posts 7 Posters 435.9k Views 1 Watching
    • G Offline
      GACHAPO
      Windows 10.
      Never loads any other versions of firmware other than the ones listed above.
        ajb2k3 @GACHAPO
        @gachapo
        the windows link i posted is the uiflow firmware loader but it has the camera firmware in the package.
        • G Offline
          GACHAPO
          Thanks for coming back to me.
          So which one do I choose please?
            For the MK1 (no case) use cam0.02
            For the MK2 with PSRam use M5Cam-psram
            I do believe the fisheye also uses the M5Cam-psram firmware.
            • G Offline
              GACHAPO
              This is my camera;
              I have UIFLow-v 1.2.3-en loaded and I have setup an IP address but nothing is loading.
              The options I have are on the image I loaded - I see no cam0.02?
                ajb2k3 @GACHAPO
                @gachapo There should be an option in the top dropdown box to select it.
                alt text
                Click on the box next to firmware
                  Click on the M5Flow-v1.2.1-en and a box will drop down, scroll through the list and the cam firmware is near the top.
                  • G Offline
                    GACHAPO
                    That's my point - there's nothing more than the image I sent.
                    The only choices I have are on the left and the only drop down boxes are at the top and relate to the COM port and Baud rate??
                      ajb2k3 @GACHAPO
                      @gachapo said in M5 Burner Firmware Option Update:
                      Sorry No image has appeared.
                      • G Offline
                        GACHAPO
                          ajb2k3 @GACHAPO
                          Um, something is not quite correct there!
                          @watson
                            An alternative is that you can download the source code and compile it yourself.
                            • G Offline
                              GACHAPO
                              I could, if I knew how.
                              I was hoping somebody would know why I cant use the burner?
                              • m5-docsM Offline
                                m5-docs
                                Hello @GACHAPO @ajb2k3,
                                Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
                                M5Stack documentation URL
                                https://docs.m5stack.com
                                • G Offline
                                  GACHAPO @m5-docs
                                  @watson Thanks for coming back to me.
                                  I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
                                  • m5-docsM Offline
                                    m5-docs @GACHAPO
                                    @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
                                    Here's the doc for it.
                                    • G Offline
                                      GACHAPO
                                      That's great thank you - works.
                                      Is there any documentation about how to assign your own IP address to the camera please?
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                        @gachapo Do you mean this doc?
                                        https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
                                        • G Offline
                                          GACHAPO
                                          I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                                            ajb2k3 @GACHAPO
                                            @gachapo you need to recompile the code is ST mode and upload to cameea
