    69 Posts 7 Posters 435.9k Views 1 Watching
      For the MK1 (no case) use cam0.02
      For the MK2 with PSRam use M5Cam-psram
      I do believe the fisheye also uses the M5Cam-psram firmware.
      • G Offline
        GACHAPO
        This is my camera;
        I have UIFLow-v 1.2.3-en loaded and I have setup an IP address but nothing is loading.
        The options I have are on the image I loaded - I see no cam0.02?
          ajb2k3 @GACHAPO
          @gachapo There should be an option in the top dropdown box to select it.
          alt text
          Click on the box next to firmware
            Click on the M5Flow-v1.2.1-en and a box will drop down, scroll through the list and the cam firmware is near the top.
            • G Offline
              GACHAPO
              That's my point - there's nothing more than the image I sent.
              The only choices I have are on the left and the only drop down boxes are at the top and relate to the COM port and Baud rate??
                ajb2k3 @GACHAPO
                @gachapo said in M5 Burner Firmware Option Update:
                Sorry No image has appeared.
                • G Offline
                  GACHAPO
                    ajb2k3 @GACHAPO
                    Um, something is not quite correct there!
                    @watson
                      An alternative is that you can download the source code and compile it yourself.
                      • G Offline
                        GACHAPO
                        I could, if I knew how.
                        I was hoping somebody would know why I cant use the burner?
                        • m5-docsM Offline
                          m5-docs
                          Hello @GACHAPO @ajb2k3,
                          Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
                          M5Stack documentation URL
                          https://docs.m5stack.com
                          • G Offline
                            GACHAPO @m5-docs
                            @watson Thanks for coming back to me.
                            I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
                            • m5-docsM Offline
                              m5-docs @GACHAPO
                              @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
                              Here's the doc for it.
                              • G Offline
                                GACHAPO
                                That's great thank you - works.
                                Is there any documentation about how to assign your own IP address to the camera please?
                                • m5-docsM Offline
                                  m5-docs @GACHAPO
                                  @gachapo Do you mean this doc?
                                  https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
                                  • G Offline
                                    GACHAPO
                                    I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                                      ajb2k3 @GACHAPO
                                      @gachapo you need to recompile the code is ST mode and upload to cameea
                                      • G Offline
                                        GACHAPO @ajb2k3
                                        @ajb2k3 Thanks - Is there any documentation you can point me to please?
                                          ajb2k3 @GACHAPO
                                          • m5-docsM Offline
                                            m5-docs @GACHAPO
                                            @gachapo At main.c file
