๐Ÿค–Have you ever tried Chat.M5Stack.com before asking??๐Ÿ˜Ž
    69 Posts 7 Posters 435.9k Views 1 Watching
    • G Offline
      GACHAPO
      I could, if I knew how.
      I was hoping somebody would know why I cant use the burner?
      • m5-docsM Offline
        m5-docs
        Hello @GACHAPO @ajb2k3,
        Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
        M5Stack documentation URL
        https://docs.m5stack.com
        • G Offline
          GACHAPO @m5-docs
          @watson Thanks for coming back to me.
          I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
          • m5-docsM Offline
            m5-docs @GACHAPO
            @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
            Here's the doc for it.
            • G Offline
              GACHAPO
              That's great thank you - works.
              Is there any documentation about how to assign your own IP address to the camera please?
              • m5-docsM Offline
                m5-docs @GACHAPO
                @gachapo Do you mean this doc?
                https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
                • G Offline
                  GACHAPO
                  I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                    ajb2k3 @GACHAPO
                    @gachapo you need to recompile the code is ST mode and upload to cameea
                    • G Offline
                      GACHAPO @ajb2k3
                      @ajb2k3 Thanks - Is there any documentation you can point me to please?
                        ajb2k3 @GACHAPO
                        • m5-docsM Offline
                          m5-docs @GACHAPO
                          @gachapo At main.c file
                          • G Offline
                            GACHAPO
                            Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
                            • m5-docsM Offline
                              m5-docs @GACHAPO
                              @gachapo
                              Download the firmware of ESP32CAM
                              • G Offline
                                GACHAPO
                                ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
                                  ajb2k3 @m5-docs
                                  @watson I can't use the M5burner of the Stick C as it it coming up as
                                  Port: "dev/cu.serial-6D52F9B441
                                  instead of the expected
                                  Port: "dev/cu.SLAB_USBtoUART
                                  • m5-docsM Offline
                                    m5-docs @ajb2k3
                                    @ajb2k3 Are you working with Mac OS?
                                      ajb2k3 @m5-docs
                                      @watson
                                      Yes, but is only the StickC that is giving the strange port ID.
                                      All others report normal port.
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                        @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                                          salty_good
                                          I understood this problem.
                                          We need to fix M5Burner for mac.
                                            ajb2k3 @salty_good
                                            @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                                            Can you add drop down box to select port?
                                            ใƒใƒผใƒˆใ‚’้ธๆŠžใ™ใ‚‹ใŸใ‚ใฎใƒ‰ใƒญใƒƒใƒ—ใƒ€ใ‚ฆใƒณใƒœใƒƒใ‚ฏใ‚นใ‚’่ฟฝๅŠ ใงใใพใ™ใ‹๏ผŸ
                                            With your input, this post could be even better ๐Ÿ’—
